Ds6 S3
Discussion in 'Home Cinema Speakers' started by ISHANTY, Sep 29, 2003.
  1. ISHANTY
    ISHANTY
    Sep 13, 2002
    556
    3
    28
    UK
    +66
    I'm thinking of upgrading my 602 S3 for these DS6 S3 for rears i need all your feed back
    what is mean by dipole mode and monopole modes and you veiws on these speakers
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Taken from the description of the speakers on B&W's own website :-
    Surround speakers generally fall into two main types – those that one might describe as 'normal' speakers - so-called monopoles, where the sound comes from a set of drive units mounted on the front of the enclosure - and those that give a more diffuse sound field, such as dipoles. Each type has its advantages.
    Most multi-channel music is recorded with home entertainment in mind and is generally monitored using two, three or four monopole surround speakers. This enables good location of side and rear images.
    Conversely, most films are originally balanced for cinemas, where a large number of speakers spread around the auditorium are used to create the surround sound field. With more surround speakers than discrete channels of information, a less precise image is created that gives an all-enveloping effect. Dipoles, rather than monopoles are better at recreating this type of sound field in the home, while using fewer speakers to do it. Dipoles do not image as precisely as monopoles, but they can make it easier to balance the whole system for a larger listening area.
    The DS6 S3 offers a choice of both monopole and dipole operation, so you may choose whichever type of operation best suits the conditions of the listening room, the size of audience and the type of programme being played. Indeed, you may use different modes for side and rear speakers, or change the characteristic for different types of programme
  3. ISHANTY
    ISHANTY
    Sep 13, 2002
    556
    3
    28
    UK
    +66
    thanx for that i now understand it
