Ruby Eyed Owl
Established Member
Hi.
I picked up my DS tonhgt as always and started playing.
I then noticed that there seemed to be some light escaping from near the bottom screen.
It seems the that the matt plastic - the bit that holds the buttons is coming away from the glossy plastics allowing light to escape.
I also took out the GBA cover cart and it seems that there is a small open area on the left hand side that is letting out alot of light too
Does anyone else have this problem. You can only see it in darker enviroments.
Will see if i can get a decent picture to post.
