Dry Mist Sunscreen
Garry123
Has anyone used Ambre Solaire Dry Mist? Seems a good idea compared to traditional sunscreen. Having hairy arms etc, its a nightmare using cream. Even the spray stuff.
sniffer66
Cheers I'll have a look at it.
Well worth a go. It's like a very thin oil. Put it on once before you go out in the sun and leave for ten mins while you eat. Then you don't need to put it on again the whole day, even if you swim. I'm hairy and it goes in very easily as it's so light. After ten mins it's completely soaked in and your skin is dry
Have a look on Amazon and check out the reviews
Garry123
I assume p20 will rub off if you go in the pool and then lie on a towel?
IanW1977
Yeah I used the calypso once a day last summer for 2 weeks in Spain. Great stuff and no sunburn. I was in and out the pool without re applying
SBT
I'll have to give that a try. I Had enough sunblock on that I looked like a channel swimmer, and still got burned :(
IronGiant
How old was it SBT? the UV protection does reduce with age and it's not just hype to get you to buy new stuff every year (unfortunately). Myself I prefer a hat :)
Sony A84L/A80L BRAVIA XR OLED TV Review - COMPARED to LG C3, Samsung QD-OLED & LG G3
Back
