Dropping Frames
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by andystud, May 2, 2002.
  1. andystud
    andystud
    Whenever i try to import video from my DV camcorder, via my PC's firewire card i drop frames and the captured avi file is jerky.
    What is the best way to overcome this.
    Is it a hardware issue or a software issue.
    I am thinking about upgrading my CPU as i am running XP with a 500MHz processor, but if its a problem with the way i am importing can someone give me some advice.
    I have tried importing using Adobe Premiere 6, Ulead media studio, scenalyzer and they all drop frames.
  2. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    By, and sometimes in, the sea
    Most likely this is a disk problem, although the processor is maybe a little slow. You should be using minimum ATA100 drives and should make sure DMA is enabled.
  3. JefUK
    JefUK
    Mar 31, 2002
    448
    28
    +54
    Almost certainly this is a HDD speed problem. Capturing DV does not require a lot of processing only packaging the DV into an AVI and a seperate audio channel within the AVI.
    Dubbing Mixer is right about setting up the HDD, but try closing all other applications (use Ctrl/Alt/Del) and minimse the capturing application.
  4. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    It may also be worthwhile closing down superfluous applications and disabling the clock display in the task bar, 'Find Fast and anything else which is running and has no bearing on what you are doing.
    I shoudl have mentioned disk speed before. (Thanks JefUK) Apart from the speed of the interface, you also need to consider the rotational speed of the drive. IDE drives are commonly available in either 5400rpm or 7200rpm flavours. 5400 is adequate, usually, but if the system is on the same drive with swap file etc. this may be the problem. The other thing to consider is cache size (on the drive, that is) 2MB should be fine less, maybe not, more ought to be fine.
  5. Arthur.S
    Arthur.S
    Are you using a dedicated HDD for the video, or using the system drive?
