Dr.Rock
Using Pinnacle Deluxe on PII-450 computer. Problem is when I capture footage via DV link, picture is fine but at times the audio is dropped. It would go slient for about a quarter a second. Each time I recapture, it happens but at different points of the captured movie, so I know it's nothing to do with the DV original recording.
Any ideas why this is so? Hard disks set ro DMA enabled as recomended. I use KillEmAll software to disable any background-running crap that might slow my system down.
Thanks.
Thanks.
