drop ds lite (schematic needed ds lite)
Discussion in 'Nintendo Forums' started by nodwas, Feb 4, 2009.
  1. nodwas
    nodwas
    Feb 4, 2009
    2
    hi dropped my ds lite ,
    got it stripped down to motherboard. check'd switch. just doesnt power up. light comes on for one second .
    does anyone no or could shed any light on what i should chech out next.
    i would be most greatful
    nodwas
  2. G a f f e r
    G a f f e r
    Dec 31, 2003
    3,042
    U.K.
    +666
    Hi.
    Try searching for "blown fuse DS" on Google.....commonly a fuse in the power circuitry blows and the light on the DS will light but it won't charge or turn on.
    It doesn't usually occur due to specific drops, but it's a starting point (hope you get it sorted :smashin:).
  3. nodwas
    nodwas
    Feb 4, 2009
    2
    thank you for you help. found the problem to be a fried battery. i realised once i took it apart, there was two fuses ,one on the chargeing side and one on the battery side. i didnt relise they was seperate system lol. thank for you reply did help.
    nodwas
