Flakey1977
Head to head between the 1 inch sensor on the Phantom 4 Pro & the 1/2 inch sensor on the Mavic Air 2. What's the difference between the images and what's the best bang for buck?
.Are you sure you didn't have a Nikon D6 taped to the bottom of your drone?
Excellent quality photo.
