DRM?
Discussion in 'Blu-ray & DVD discs' started by wapanap, Feb 21, 2014.
  1. wapanap
    wapanap
    Feb 21, 2014
    4
    Is there any form of DRM that prevents one recording hi def movies from TV via a blu-ray recorder onto blu-ray disks?
  2. Pecker
    Pecker
    Dec 26, 2004
    22,494
    Huddersfield, People's Republic of Yorkshire
    +4,612
    As far as I'm aware, none of the Blu-ray Disc recorders have HD inputs, so the only way to record HD is through an internal tuner.
    I think you can then burn these to disc, but I've heard some broadcasts have some sort of DRM so you can't.
    It's quite crazy. I can rip my excellent quality 1080p/ lossless audio Blu-ray Discs using free software like MakeMKV, but they're frightened of me burning a low bitrate Dolby Digital 1080i broadcast.
    Steve W
  3. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,016
    Poole
    +10,887
    There isn't a HD output on a TV.
    Plus there are copy protection mechanisms.
  4. wapanap
    wapanap
    Feb 21, 2014
    4
    The Panasonic DMR-BWT735 recorder can record hi def programs to hard disk and then archive them to blu-ray disks. i want to know if anything prevents you doing this with movies.
  5. wapanap
    wapanap
    Feb 21, 2014
    4
  6. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,016
    Poole
    +10,887
    Programmes are broadcast with copy protection flags which are recognised by the recorder.
    For films they will be set.
  7. wapanap
    wapanap
    Feb 21, 2014
    4
    But you can record hi def movies to the hard disk of a Virgin box.
  8. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,016
    Poole
    +10,887
    Yes because that is contained within VM's system.
  9. smackos
    smackos
    Jan 8, 2007
    1,656
    3
    4
    116
    +701
    Basically you can archive anything to a BD recorders HDD, but it'll still only allow SD burning to a disc IIRC. Also as already stated even some content shown has flags that'll prevent disc burning.
