driver issue or setting issue?
Discussion in 'PC Gaming & Rigs' started by MikeKay1976, Aug 12, 2013.
  1. MikeKay1976
    MikeKay1976
    Feb 1, 2005
    8,393
    +1,986
    Hi, I havent looked into this too much so am sure it is a simple fix however.....
    I have recently gotten into playing crysis warhead. All was fine and was playing at 1080P 60hz.
    yesterday however i reinstalled nvidia 3DTVPlay trial.
    Even with the "enable 3D box" unchecked in the drivers, all of a sudden now when i load up crysis it changes my resolution to 1080P 24hz - even though my desktop is at 60hz.
    After having a bit of a tantrum on it I decided to leave it alone for a while.
    I did a quick google and there didnt seem to be a sensible solution, though others were having the issue (apparently running in DX9 fixes is according to some, but stuff that!, my pc runs it just fine in DX10)
    have you guys seen this issue?
    cheers
  2. bladedripper
    bladedripper
    Nov 26, 2007
    5,071
    Birmingham
    +1,527
    You needed to make a custom rez in NVidia control panel for 1080p/60...:smashin:
  3. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
  4. MikeKay1976
    MikeKay1976
    Feb 1, 2005
    8,393
    +1,986
    thanks for the info.... Wow, what a silly bug! and not been fixed for over a year.
    out of curiosity is there a reason for this bug?
    cheers (I will google when i get home from work if no one knows)
  5. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
    Your welocme mike. Its been like that since release and also can effect some other games, I haven't a clue why it happens but its pretty poor that it hasn't been patched out.
