drilling steel cabinet - any tips?
mrbenn
Dave
Yep, grommets good idea. Also make sure you run a file round it after drilling.
If you have a clamp then use that to secure a piece of scrap wood behind the hole you are drilling. It will stop the metal flexing so much and possibly bending.
If it's a large hole then it's always easier to start smaller and work your way up. Good drill bits make the job a lot easier unless you get cheap one's and bin them after a couple of holes.
mrbenn
thanks for the info :thumbsup:
Pending thickness lube, WD40, GT85 or OIL.
Speed, have the bit running fast but drill slowly.
Like Dave said, the wood stopping the flex helps big time!
