Drilling a concrete ceiling
Discussion in 'Home Cinema Building DIY' started by Fonzerelli, Jul 26, 2004.
  1. Fonzerelli
    Fonzerelli
    Jan 19, 2004
    149
    Hello,
    Im trying to drill holes in my ceiling for my PJ mount, but i live in a flat and the ceiling is rock solid, im assuming its made from concrete. my cordless drill isnt getting in at all, any ideas what i need to do this?
    im assuming the cordless drill isnt creating enough torque? also what kind of drill bit is needed?
    TIA
  2. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    You are right that a cordless drill is not man enough for the job generally.
    You need a SDS drill (pneumatic) and masonary bit. These make light work of drilling through masonary and concrete but be warned they are bloody heavy when drilling upwards.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,754
    Somewhere in South Yorkshire
    +4,908
    A mains electric drill with hammer action may be more effective. And you need to use a masonry bit. Regular (wood/metal) bits will get hot and blunt in seconds.
  4. Fonzerelli
    Fonzerelli
    Jan 19, 2004
    149
    Thanks guys, ill look into buying a proper drill bit and lend a drill :)
    dont worry about me having to lift it, im rock hard :laugh:
  5. cwoj
    cwoj
    don't forget to use proper concrete fixings / compression bolts. screwfix sell loads of different types :D
  6. LV426
    LV426
    Jul 14, 2000
    12,754
    +4,908
    ....and match the size of the masonry bit to the hole size required by the fixings.
  7. Roguey
    Roguey
    Aug 1, 2004
    203
    +13
    oh, and dont drop the drill on ur head when lifting up :laugh:
  8. avanzato
    avanzato
    Jan 21, 2003
    1,874
    Norfolk
    +60
    ..and wear eye protection, the PJ'll be no use if you're blind
    ..and don't drill through the ceiling ;)
  9. Roguey
    Roguey
    Aug 1, 2004
    203
    +13
    drilling thur the celling, :laugh: oh wonder what that is in the floor, oh its just an drill from downstairs
  10. Fonzerelli
    Fonzerelli
    Jan 19, 2004
    149
    lol all went well guys :D used goggles and what not and the drill bit just sailed through, i used a cordless drill a few months back to try and drill a couple of holes to mount some speaker brackets, it left a mess all over the walls lol the masonery bit did the job though :)
