DRH Screen retraction VERY difficult
Discussion in 'Projectors, Screens & Video Processors' started by Fjorko, Sep 5, 2004.
  1. Fjorko
    Fjorko
    Apr 25, 2003
    511
    Port Elizabeth
    +24
    HI Guys
    I got my 6ft DRH yesterday. had a friend mount it for me, but i am having a right struggle to get the thing to retract completely... :mad:
    I have 90cm of Black drop on top, and it seems to have been "Glued" to the standard 6ft screen ( you can feel and see it on the back ) ;)
    Now i have read that you need to TUG it down firmly and follow it up at a good rate, but with all this tugging, can the screen not tear on this joint after a few tugs ! ??? Maybe Mr. Screen can comment here ! :confused:
    What are you using to fix the Large black drop to the screen ? If it's glue, will it withstand all this tugging to get the screen to retract. I'm almost to scared to tug too hard in case the two pieces of fabric come away from each other. :eek:
    Thanks :smashin:
  2. Mr Screen
    Mr Screen
    May 4, 2004
    52
    North London
    Hi Fkorko
    The screen can be pulled very firmly indeed it is joined with a speacial tape its not an ordenary tape you could hang on it and it would not come off though best not to do that thats how strong it is.The only way the ends might get damaged is if you let the screen go with both hand thats not a good idea.
    Remember you dont have to be to gental with it its more robust than you think.
    Mr Screen
  3. LDR
    LDR
    Apr 1, 2002
    2,332
    Wales
    +101
    I have to say Im very pleased with my screen purchase from DRH, yes the retraction can be a bit fiddly, but you'll soon get the hang of it, only slight gripe I have is that the black borders on the side started to curl, however the actual viewable white screen is perfect, which is far more important. Good service and great prices from DRH, highly recommended.
  4. Fjorko
    Fjorko
    Apr 25, 2003
    511
    Port Elizabeth
    +24
    Dont get me wrong, i think it's an excellent screen, just the retration seems to be a bit of a mission, but, today i tried a few times and i seem to get the hang of it now!!
  5. Benrudd1
    Benrudd1
    Jan 19, 2003
    961
    Pembroke Dock
    +66
    It does seem to ease up after a while and gets easier to release. (or you just get the hang of it :) )
    If you're worried about the glue joint, don't! I've accidently let mine go twice now, after the tug to get it to release. Makes a heck of a bang when it hits the top :blush: .
    Still no sign of damage on the top join though.
  6. Kramer
    Kramer
    I'd be more concerned about warping the bottom "slat" bar...............could result in ripples :eek:
