DRH Screen Casing
Discussion in 'Projectors, Screens & Video Processors' started by CrispyXUK, Mar 10, 2005.
  1. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,777
    71
    Land of the Living, Essex
    +49
    Hi all,
    I'm looking at purchasing a slimeline drh screen (1450mm Width) but the casing is too wide (1620mm) is there any way of reducing the casing? does it have end caps I can remove?
    Any help would be greatly appreciated
  2. avanzato
    avanzato
    Jan 21, 2003
    1,970
    Norfolk
    +83
    The end caps hold the bearings that the screen tube runs on so they can't be removed. Have you asked DRH if they have any suggestions, you could have the same size image from a slightly smaller screen by not having black boarders for instance.
