DRH High gain material no more ?
Discussion in 'Projectors, Screens & Video Processors' started by dfield2000, Dec 23, 2003.
  1. dfield2000
    dfield2000
    Jul 16, 2002
    957
    Cardiff
    +5
    I'm building my own screen and decided to get the High Gain material from DRH - this appeared to be in the middle of their other two products - cheaper that the High Colour stuff, and slightly more expensive than the standard Mat White.
    I thought the High Gain is what most people recommend as it is about 1:1.2 gain - but when I phoned to order it the chappie said that he doesn't do the High Gain anymore - just the Mat White or High Colour.
    He said that 99% of the screens they sell are all Mat White and this stuff would be fine - so I've ordered it - but thinking about it now, am I loosing out on performace from this 1:1 stuff - would I see a benefit by getting a higher gain material ?
    I'll be running a Z1 when it arrives.
    Ta.
  2. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Matte white is wot you need for a LCD PJ anyway so don't worry.
    I've got a DRH screen in that material and its excellent with my Z2. Theres some screen shots here if your interested.
  3. dfield2000
    dfield2000
    Jul 16, 2002
    957
    Cardiff
    +5
    Cheers man. Another one of my 'worries' put to bed.
    Far too many decisions to be made with this projector lark - I'm constantly thinking I've made the wrong decision about something.
    Ta.
    P.S. those screenshots look great.
