smartiepants
Established Member
- Joined
- Jan 22, 2004
- Messages
- 219
- Reaction score
- 9
- Points
- 64
Just ordered my electric screen frm DRH after reading good reports from this forum
I have ordered a 4x3 screen & will try to use the relay from my projector to trigger the lowering & raising of the screen
here's the problem
can i lower the screen & stop it to fit 16x9 when i want to watch 16 x 9 movies & then drop it again to fit 4x3 to watch my 4x3 dvds
the only reason i went for a 4x3 screen is that lots of my DVDs are 4x3 & don't want to compromise & butcher the image down to 16 x 9
I am planing to mask the top of the screen when viewing 16x9 but cannot mask the bottom so the obvious answer would be to stop the screen when at the right level
can this be done
The guy from DRH tells me i can raise, lower & stop at dirrerent heights with the switch but can i do it with a relay????
here's the problem
can this be done
