DRH electric screen drop adjustment??
Discussion in 'Projectors, Screens & Video Processors' started by Smokin..o0O, Jan 10, 2004.
  1. Smokin..o0O
    Smokin..o0O
    Dec 2, 2003
    148
    Scotland
    +15
    Just got myself a nice 2.3 metre widescreen from DRH.
    I have "rough" installed it to double check positioning.
    I have also replaced the rocker switch with an RF remote control relay assembly. Using the remote will only allow me to fully lower or fully retract the screen.
    Is it possible to adjust the drop stop of this screen?
    I did email the supplier a few days ago, but as yet, no reply :(
  2. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    yeh you can adjust it.
    At the left end there is a small hole for a screwdriver. There are two adjustments, one for drop the other for fully retracted. One is accessable the other you need to take the end of apparently. Unfortunatly I cant remember which is which.
  3. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    more info in this previous thread.
    hth
  4. Smokin..o0O
    Smokin..o0O
    Dec 2, 2003
    148
    Scotland
    +15
    Excellent guys, thank you very much:smashin:
  5. BestGear
    BestGear
    Oct 22, 2003
    1,258
    +45
    Hi ... a slight aside...!
    How is your screen for wrinkles etc?
    ...just interested to know!!!
    David
  6. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    its fine.
    As I've stated before, the outer edges curl a little but its only on the masking, the image area is flat. It was like it from new and doesnt affect the screens performance.
  7. BestGear
    BestGear
    Oct 22, 2003
    1,258
    +45
    Thats very good to hear!
    I dont mind a slight curl on the black stuff... the white is flat...
    Thansk for the info
    David
