DRH Easy Pull Up Screen
Discussion in 'Projectors, Screens & Video Processors' started by markwww673, Nov 1, 2003.
  1. markwww673
    markwww673
    Oct 31, 2003
    2,945
    103
    Midlands
    +321
    Considering this screen @ 145cm width 16:9 ratio with a Optoma H56 projector from 9.8 feet the max room i've got. A fixed screen is not really an option
    Is this a good combination for a newbie with a first projector
    thanks for the help
  2. Kramer
    Kramer
    Hi & welcome :)
    5' wide screen with a viewing distance of 9' should be fine. Also have a look at the FAQ at the top of this forum.......loads of useful info/links to be found there.
    :smoke:
  3. stubie_do
    stubie_do
    Sep 8, 2002
    243
    Suffolk
    +33
    You should be OK with a 145cm screen at that distance. Calculations are as follows using the 145:
    Minimum throw distance is 9.51 feet (2.9m) - Maximum 11.4ft (3.48)
    If you have a look at our US website you will see the new H30, H56 & H76. On the site you can use the online calculator to find the throw distance or screen size. Always allow app +/- 5% tolerance on the calculations. I hope this helps.
    You can find it at www.optomahometheater.com
    Regards
  4. markwww673
    markwww673
    Oct 31, 2003
    2,945
    103
    Midlands
    +321
    thank you both for the help
    all very ueful info
    mark
