Dreamcasts
Discussion in 'Nintendo Forums' started by mattruston, Aug 6, 2003.
  1. mattruston
    mattruston
    Does anyone know where to buy a new dreamcast from? I've been having real trouble with dreamcasts, i've gone through 5 in the last few months, i know they are notorious for breaking down. Anyone know where i can purchase a new dreamcast? I've only seen it for £80 online, seems a bit pricey to me.
    Cheers :)
    Matt
  2. meva
    meva
    Feb 20, 2001
    348
    cornwall,uk
    +13
    The odd new one pops up on e-bay. What has been happening to them? I've just fixed 2 dead ones with a new power supply for each from www.play-asia.com. About £12 including p+p and an easy job.
  3. mattruston
    mattruston
    i don't know, i just find them so unreliable.
    The one i have currently just doesnt display a picture. I plug in the scart, no picture. Then i plug in the rf lead, no signal at all.
    Its strange eh?
    The other ones i have had just seem to go kaput!
    is there any warranty offered on the dvds you fixed?
    not even a 90 day good will guarantee?
  4. meva
    meva
    Feb 20, 2001
    348
    cornwall,uk
    +13
    Eh ???
    The ones that just went kaput, I bet they just needed a new psu.
    The £12 including p+p if for a new power supply from play-asia ,they don't fix it for you . It's dead easy to fix yourself.
    As far as the problem with your current DC try
    http://www.dcemulation.com/phpBB/viewtopic.php?t=4557
    or a search of the forums there. A great many DC repairs are pretty simple . Putting the new power supply in is as easy as putting ram in a pc.
