Dreamcast VGA Advice
Discussion in 'Projectors, Screens & Video Processors' started by GarryF, Jan 19, 2001.
  1. GarryF
    GarryF
    Aug 30, 2000
    1,429
    83
    Scotland
    +339
    Will I get a better picture if I get a VGA cable for my dreamcast ?
    currently I have a projector with a quadscan scaler which has a VGA passthrough socket so it would be pretty easy to setup a new convergence for the dreamcast, just wondering if there would be any picture benefit
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Probably. You should get a higher res. output from the VGA output. If you are using RGB at the moment you may not be abel to tell a lot though. Try it and see, then tell us all!
    Rick
    'I am just a figment of your imagination.'
    MiB 1997
    Work Site: The Sound Gallery
    Home Site: WD A.V.
