Dreamcast Resetting Itself
Discussion in 'Nintendo Forums' started by wolfeh, May 26, 2003.
  1. wolfeh
    wolfeh
    Feb 21, 2003
    421
    Ramsgate, Kent
    +10
    Hi, I've not played my DC in ages (february), so I got it out today and hooked it all up and went to play it. Then the problems started, after being turned on for a few while (im talking under a min) the console resets itself and loads the game up again. I've no idea what it could be. Curious to see what it was I opened up the console to see if I could see any loose connections inside or anything. This is where I noticed that the top was only held to the base by 1 screw, the others were all missing, and that the drive unit wasnt screwed to the main board (it was just resting on some rubber cushions), could this be a problem?. I brought the DC 2nd hand of ebay middle of last year and haven't had any trouble with it untill now :/ anyone have any ideas? :confused:
  2. RL123
    RL123
    Nov 4, 2002
    1,037
    38
    +4
  3. wolfeh
    wolfeh
    Feb 21, 2003
    421
    Ramsgate, Kent
    +10
    :clap:
    I tried the lens cleaning and the "cleaning" of the power supply pins, and now it works fine :D
    Now where is jet set radio.............
  4. RL123
    RL123
    Nov 4, 2002
    1,037
    38
    +4
    Glad it worked :) Well done mate
  5. hamtaro
    hamtaro
    sounds like the drive is on its way out, if im right ..cleaning the lense won,t help. i know this to be true because the same happened to me
