Treetops77
After a bit of advice.
Trying to install a Drayton wiser kit, thought it would be as simple as removing the old (Drayton lp552) and installing the wiser hub. Wrong haha
So the hub lights up and connects with my phone/app all fine. It's just that it doesn't trigger the boiler, now I've set my 2 current thermostats (Drayton RTS1) to max and the boiler display just reads - 'Timer or room stat off'
I've attached a photo of the backplate for the hub.
The instructions mention something about linking L to 1 on the backplate but I was unsure if this applied to my setup
If this is all that needed then great but I just want to know before I try it and be disappointed or break something.
Thanks in advance
Thanks in advance
