Draper or Da-Lite?
Discussion in 'Projectors, Screens & Video Processors' started by Gary Lightfoot, Jul 8, 2003.
  1. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,443
    Surrey. UK.
    +2,103
    Hi all,
    someone has asked me which matt white pull-down screen would suit his HS10 better - a Draper or Da-Lite.
    He's after a 92 x 52 screen for his lounge.
    Any advice for him?
    Many thanks
    Gary.
  2. Klippie
    Klippie
    Dec 1, 2002
    628
    Scotland
    +58
    Gary,
    I have a Draper Luma matte white pull down 72" wide screen, I must say for the money its quite good and it gives a very satisfactory picture with my HS10 but it does have one or two wrinkles and they can distract me from time to time on panning scenes in films. Its much better than the painted wall I was using before though.
    Overall I would recommend Draper for your friends first screen but if I were to buy a screen now I would spend the extra and buy an Owl, I saw one recently which was nice and flat and the electric control would be great.
    Klippie.
  3. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,443
    Surrey. UK.
    +2,103
    thanks for that Klippie, I'll pass the info on.
    Cheers.
    Gary.
  4. Paul Williams
    Paul Williams
    Jul 4, 2003
    789
    Plymouth/Devon
    +15
    Hi Gary,
    I have recently bought a Draper and cannot say that I'm that impressed. Regular horizontal lines/wrinkles across the screen, presumable where it is attached to the internal roller. My initial thought was to get a DRH screen ( www.drhscreens.co.uk ) but I was seduced by the Draper High Contrast Grey. Obviously I don't know if this is a factor in the problem I'm seeing. Don't get me wrong the image is still perfectly watchable but occasionally these do intrude.
    Paul
  5. Jonny1973
    Jonny1973
    I have a DaLite Model B 80" screen which also has ripples.
    I get the impression that all cheap (£200) screens get this. To avoid it i think you need to buy either a screen made from thicker material (£500) or a tensioned screen (£700).
  6. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,443
    Surrey. UK.
    +2,103
    Great info guys. He was wondering about spending a bit more than £200 - £300, and those are good reasons for doing so.
    Thanks again
    Gary.
  7. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Gary,
    I bought a grandview electric from www.intoav.com which is a very good da-lite copy. It cost about £500.00 and its very good. There is a very slight curl on the right, but as the screen is staying down as in dedicated AV room, I simply hold the 'slight' curl back with some blue tak.
    However, when I was demoing a few PJs after my Z1 saga, I actually saw an OWL electric and I have to say that I wish I had bought one of these. I was offered a six foot screen by a local dealer but turned it down as it was a bit too expensive, given my budget, and the Grandview was already bought.
    Anyway, it creamed on all other screens. When it dropped it was completely flat and there was absolutley no curl ,rippling or defects to be seen. In the context of the demo room I saw it in, the screen must have been up and down like a fidlers elbow. A First class product.
    So, tell your friend to check out OWL.
    Hope this helps.
    Cap
  8. Threadkiller
    Threadkiller
    Aug 23, 2002
    63
    I've got a Da-lite model B 52x92 that I love, cant say I've noticed ripples as such, but I've got to get rid of it as it doesn't fit in my new house :( touches the wood burner when in use.
    A colleague has a Draper Luma which I quite like, not the same quality as the Da-lite IMHO but a decent enough substitute.
  9. Mr. Wilby
    Mr. Wilby
    Dec 15, 2002
    636
    +16
    Messiah also swears by his Owl for the same reasons as 'captain said. Like glass IIRC...
