Draper Luma or DRH Slimline???
Clint C
Don't know which one to go for, I'm assuming coz the Draper is more expensive that it's better? :confused: could be wrong though. Any thoughts?
7 foot Draper Luma, £230
7 foot DRH Slimline, £158
So £70 ish difference.
Clint.
CooperUK
Yep, I'd like to know as well.
Anyone used Premier Presentation who advertise mainly on eBay?
2m screen from them would be about £100.
Many thanks for any help/response.
Q
Quatermass
The impression I have formed from posts on the forum is that people prefer DRH's to Drapers.
I got a pull down DRH Slimline and it is very good. Probably the only gripe I have with it, is that it was quite tricky to put up. Plus it would be nice if the screen housing was black!
Clint C
Cheers buddy :smashin:
markwww673
the DRH slimline is a very good choice.
It does take a bit of practise pulling up and down (the advice from DRH) was not to be to gentle with it.
Marcus
Clint C
Thanks for the extra confirmation guys :smashin:
Clint.
William123
DRH SLIMLINE
It's a very fine screen for the money albeit that is does need a bit of rough to retract it....well pleased
Chaos Star
Just fitted a DRH screen today and cant get it to go back into the housing - I have pulled the screen down to its maximum drop and still cant get it to retract - any tips on getting it back into the casing. Ive tried pulling it at all angles using reasonable force to no avail.
Clint C
Piero, answer here
Clint
[email protected]@y
Ive just sold my draper luma 106" screen as it would fit between the purlins beams in my loft..I opted for a smaller DRH slimline and Im not impressed :(
The DRH feels very cheap indeed compared to the draper...it also exhibits some screen curl at the edges where the draper did not.
If I had the option again Id definately go for the draper :rolleyes:
Mr Screen
Hello Guys and girls
I work for drh screens and would be pleased to answer any questions you might want answered before you take the plunge and buy one of our products.
Big bad joy
sorry to hear your not happy with our product when did you buy it? the thread was all going so well up to your post:( lucky for us most people that by our products are satisfied.
Regards
Mr Screen
(Andrew H)
Clint C
Hi there Mr Screen
What's all this I hear about having to yank the thing damn hard to get it go back up :D . Your screen certainly seems competively priced compared to the Draper and that's always welcome. Are there any plans to sort out this common problem with the retraction of the screen back into the casing?
Clint.
Mr Screen
hello Clint
thats just not true,you dont need to yank it all you have to do is give it a sharp jerk down and follow up straight away there are two ratchets on the spring and if you go to slow on the way up the ratchet locks up, all the screens are tested before they go out,i am surprised how many people have trouble with them.
Mr Screen
[email protected]@y
Hi Mr Screen.
I bought it a couple of weeks ago and have only just put it up in my loft. The draper just seemed to be made from thicker screen material and a stronger casing.
I suppose I have to take into account the £30-£40 price difference but the slight screen curl is a little annoying. I havent tried my projector on the screen as yet but hope the picture will be just as good as with the draper.
(I also found the mechanism much trickier to retract the screen than the with the draper)
ibster
how about doing a forum special :) on your screens, im sure there are loads of potential buyers on here
Mr Screen
ok how do i go about this as i have never done anything like this before:confused: I would guess the most popular screen and size would be 7ft manual 16:9
please give me your opinions .
:thumbsup:
Clint C
Mr Screen
I suppose the best way is to contact a moderator to find out the process.
7ft 16:9 sounds good to me :D .
All the best
Clint.
Oh and don't forget to make it an unbelievable offer so the members can't refuse ;) .
alpha10
Whats happened to the power buy??
Podcast: LG C1 OLED + JBL Synthesis SDR-35 First Thoughts, plus TV Show & Disc Reviews & more
Latest News
Austrian Audio launches Hi-X65 headphones
  • By Andy Bassett
  • Published
Roku expands streaming content with Roku Originals
  • By Andy Bassett
  • Published
What's new on Netflix UK for June 2021
  • By Andy Bassett
  • Published
AVForums Podcast: 12th May 2021
  • By Phil Hinton
  • Published
Bluesound unveils new generation of Node and Powernode audio players
  • By Andy Bassett
  • Published
