Dragontech iobox problems
mcgoverg
looking for some help.
I've been ripping dvds to iso using dvddecrypter. These are stored on the hard disk of my iobox.The problem is some play and some don't and there's no clue as to why. The ripping parameters are the same in all cases but some play and others simply return to the menu screen (where you select from movies, music etc).
Thanks for any light anyone can shed on this.
Gerry
next010
Does this Iobox support the MKV container ?
If yes what you could do for the DVD that dont work is use MakeMKV which will rip (not convert) the video and audio from a DVD then place it in an MKV container (main movie only).
If the DVD MKV plays then you at least have a workaround.
