Dragonball Z Remastered Season Dvd Boxsets
Discussion in 'Blu-ray & DVD discs' started by Alphawao, Jun 16, 2009.
  1. Alphawao
    Alphawao
    Feb 23, 2007
    354
    2
    London
    +27
    I wanted to get the Dragonball Z Remastered Season Boxsets from the US but I need to confirm if they'll work on R2 players like my PS3. On some sites it says Region 1 only and others say R1,2,4.. If anybody has these in the UK have you check the discs on a R2 machine?:smashin:
  2. Alphawao
    Alphawao
    Feb 23, 2007
    354
    2
    London
    +27
    No DBZ fans here then...oh well.
  3. Soundwave
    Soundwave
    Mar 9, 2005
    7,413
    Basildon, Essex
    +2,454
    If your importing from the US then they will be Region 1 only (My original series discs were R1 only)
    However I think these also see release in Australia & if so then they will most liekly be R2 & R4.
    Might be worth checking the obvious sites like DVD Crave for Australia release & also DVD Boxoffice for the US release
    Obviously R1 discs wont play on standard PS3 or UK players.
    Hopefully that will help??
    Neil
  4. Alphawao
    Alphawao
    Feb 23, 2007
    354
    2
    London
    +27
    Thanx man I chcecked some assie sites but they're pretty expensive...the best US price I saw was DVDPacific.
  5. damianmcr
    damianmcr
    May 13, 2007
    693
    28
    Dungiven
    +67
    They are region free. The USA releases that are.
  6. Michael
    Michael
    Jun 7, 2009
    2,538
    Truro
    +186
    Tempting to buy just for the power level episode:D
    Only if it is cheap enough, though...
  7. thedrazen
    thedrazen
    Jun 22, 2007
    2,217
    Plymouth
    +326
    deffo region free i owned season 1 for a while and can confirm it worked fine on my uk dvd players
  8. Alphawao
    Alphawao
    Feb 23, 2007
    354
    2
    London
    +27
    Thanx 4 the replies I ordered S1 from DVDPacific as they're fantastically cheap!
    I'll get the rest of the Seasons later.
  9. Tahme
    Tahme
    Jan 3, 2011
    44
    11
    London
    Hi, sorry I know it's a year on, well 2 technically but Im interested in buying the remastered DVDs also and can only find us imports on amazon and eBay which all say region 1. Was wondering if DVD pacifics copies worked on Your DVD player or your ps3 and if you think the amazon us imports are the same as DVD pacifics.
  10. hippo99
    hippo99
    Feb 29, 2008
    16,376
    163
    +9,500
    So you're asking if Funimation asked the factory to press a special region free set for DVDpacific, & then to also press a region 1 set for Amazon?
    Will the DVD's I buy from HMV be different from the DVD's I buy in Tescos?:facepalm:
    :smashin:
  11. PoochJD
    PoochJD
    Aug 28, 2000
    11,006
    Norwich
    +1,861
    Tahme,
    DVD Pacific's titles will be the same as Amazon - namely Region 1 US titles! Australia has sets available, but they are Region 4 only. As such, unless you have access to a mutiregional DVD player, or region-free DVD drive, the discs are highly unlikely to work in your PS3 or DVD player!!!
    Pooch
  12. hippo99
    hippo99
    Feb 29, 2008
    16,376
    163
    +9,500
    The 'remastered' set (ie orange box set) is actually region 1, 2 & 4 so will work fine in the UK:thumbsup: (check the reviews on Amazon Amazon.co.uk: Customer Reviews: DragonBall Z: Season One (REGION 1) (NTSC) [DVD] [US Import])
    Not just the sets from DVDpacific, but from ANY shop in the USA:rotfl:
  13. Tahme
    Tahme
    Jan 3, 2011
    44
    11
    London
    Hi, thanks for the help hippo. I'm not gonna defend my other comment, i should have worded it better lol. But thanks again.
  14. PoochJD
    PoochJD
    Aug 28, 2000
    11,006
    Norwich
    +1,861
    Hi Hippo,
    If that set works on Region 1, 2 or 4, then it can't be region-encoded at all, and is presumably Region Free! Very odd decision for a company like FUNImation who normally like to keep their titles exclusive to the country's they're released in! Still, to the OP, best of luck in getting the set, and fingers crossed it'll play in your machine/PS3. :)
    Pooch
  15. hippo99
    hippo99
    Feb 29, 2008
    16,376
    163
    +9,500
