DPA32R Software and Hardware Version.
Discussion in 'AV Receivers & Amplifiers' started by the_third_man, Aug 28, 2006.
Tags:
  1. the_third_man
    the_third_man
    Apr 1, 2006
    60
    11
    Bristol
    +3
    Hi all.
    What was the latest software version installed in the DPA32R pre-amp? Mine has V1.07.4 as shown at switch-on. If it's not the latest, presumably I need the TAGtronic adaptor cable to down-load it from a PC.
    To check that it also has 192KHz DACs fitted, what do I look for? A certain chip-set or something else?
    Thanks,
    Richard.
  2. liam_b
    liam_b
    Apr 24, 2002
    390
    28
    Wilds of north Leicestershire
    +25
    As far as I know 1.07.4 is the last version TMA produced.
    Re the 192K DAC look for DPBxxxxx on you serial number number, they're all 192K versions.
    Or is your unit is a DPAxxxx serial, remove the lid and look for a chip with
    AKM
    AK4395VF
    xxxxxxxxxx
    all printed on the top, usually in white but may be laser etched. This will be next to a red ELNA 470uF 16V capacitor about 3 1/2" behind the left hand edge of the front panel LCD as you look at the unit from the front.
  3. the_third_man
    the_third_man
    Apr 1, 2006
    60
    11
    Bristol
    +3
    Thanks for the info, Liam. The serial number is DPB-00000907, so that clinches it.
    Regards,
    Richard.
