dpa32r fault
Discussion in 'AV Receivers & Amplifiers' started by david1961, May 3, 2007.
Tags:
  1. david1961
    david1961
    Nov 8, 2005
    256
    melbourne
    +27
    Hello
    hoping someone may have some ideas?
    I have or had a dpa32r (sold it to my brother)
    It was playing, then goes off screen goes blank ,then comes up with selftest again
    When you turn all power off and back on again it wont play anymore and keeps self testing .
    Next morning when cold played about 6 tracks before selftesting
    Would reloading software be any help?
    Has anyone experienced this ?
    Any ideas ?
    David
  2. daveymcd
    daveymcd
    Apr 19, 2006
    154
    Is it resetting? It sounds like the power supply might have broken down, this happened to mine and I had to send it back to IAG to be replaced :(
  3. david1961
    david1961
    Nov 8, 2005
    256
    melbourne
    +27
    Thanks for shedding some light
    Yes it works a bit then selftests
    Plays the music fine when it works
    Its difficult when you live a long way from iag
    The shipping costs are a killer
    The unit has done no work only had it in my system replacing a pa 20r for a couple of months then when I got the 32dp didnt need it
    So sold it to my brother ,and he lives in another state
    So yours was doing the same thing?
    David
