downloading dvd's
Discussion in 'Desktop & Laptop Computers Forum' started by Will 44, Dec 21, 2006.
  1. Will 44
    Will 44
    Mar 10, 2006
    195
    Cheltenham
    This is the first time I'm doing this so bear with me, how do you download a dvd onto my pc, when I try it just says it's copyright protected, how do I get around this? Any help much appreciated!
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    A Google search for "ripping dvds" threw up a number of references. Try this one, it is as good as any. My preferred software is DVD Shrink.
  3. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    DVD Shrink FTW
  4. Will 44
    Will 44
    Mar 10, 2006
    195
    Cheltenham
    Cheers, also as I have two drives on my pc is there any way of copying the dvd straight to a blank dvd in the other drive?
  5. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    A while ago I did use clone dvd but dont copy dvd's anymore but try http://www.videohelp.com for more info and tutorials.
  6. jaymz
    jaymz
    Mar 29, 2005
    1,015
    Sunny Norfolk
    +60
    If you have DVD shrink you can set the burn engine to be Nero (the free trial will work) and it will shrink (from double layer to single layer) using temp files on hard disk and then burn to the blank disk. You can then set it to shut the machine when it is finished.
