Download programs from sky+ to pc
Discussion in 'Sky Digital TV Forum' started by 215m3, Apr 24, 2007.
  1. 215m3
    215m3
    Dec 9, 2006
    11
    Is it possible to download programs saved from my sky+ to my pc and if so what is needed and how is it done?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    It's very easy.
    Get a PC capture device (internal or external) and feed a SKY+ video/audio output into the device and then record the programme on the PC hard drive.
    The s-video and phonos work very well since you may be using the RGB and Optical for the main viewing, worse case use the RF output of the SKY+.
    Another way is to dump to DVD and then just take the DVD to the PC:)
