Downgrade concerns/movies
Discussion in 'PS Vita Forum' started by seymourtitty, Oct 17, 2005.
Tags:
  1. seymourtitty
    seymourtitty
    Nov 16, 2003
    Hi there
    I recently bought a v1.52 PSP from Virgin, so I'm a newbie to this, so please bear with me.
    A friend at work is recommending the downgrade to 1.5 so u can play games from your memory card, but I've been told that this invalidates the warranty. So my questions are:
    What are the chances of all future games not working on v1.5? A knowing my luck, the downgrade won't work and I'll be left with a dead duck....
    Do you need 1.5 to play movies or can u convert them to the correct format (MPEG4?) and stick them on your mem card?
    I only see myself playing 3/4 games max anyway, so that cost won't be prohibitive. However it would be great to watch movies that my friends have already downloaded, before deciding whether to buy them.
    So I guess I'm asking, is the chance really worth taking?
    Thanks for your help!
  2. chrislad
    chrislad
    May 6, 2005
    5,867
    83
    Rep. of Ireland
    +153
    Technically, it shouldn't void your warranty as you are installed a legal, official Sony 1.5 firmware. You'll still be able to watch all your movies, and I haven't heard of anyone breaking their PSP by downgrading yet, expect people who used the dodgy downgrader, which was a program that broke your PSP intentionally. Get your files from pspupdates.com and not some dodgy torrent and you'll be fine.
  3. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    ive heard that to play the new gta on the psp u have to have version 2.0 or higher not sure were i read this will try and find a linky
    wallzy
  4. seymourtitty
    seymourtitty
    Nov 16, 2003
    thanks guys
    However, do u need v 1.5 to be able to watch movies from your memory stick?
    And furthermore, cant games manufacturers make games so that they are not compatible with v 1.5?
  5. Jan20
    Jan20
    Oct 15, 2003
    1,180
    Yorkshire
    +87
    This is where the lovely WAB Version Changer comes into it's own.
  6. chrislad
    chrislad
    May 6, 2005
    5,867
    83
    Rep. of Ireland
    +153
    You can watch movies with 1.0. The only difference 2.0 made was support for the AVC codec. You can still watch standard .mp4 movies.
    Like the previous poster said, there's a program called WAB Changer that makes your PSP think it's running as 2.0, 2.01 and (probably) 2.5. So you won't have any problems running newer games.
  7. Jimbo73
    Jimbo73
    Aug 22, 2004
    259
    28
    +43
    Apparently some of the newer UMD movies will not work with 1.5x.
  8. drskhaled
    drskhaled
    Feb 25, 2005
    1,541
    London
    +108
    What a damn shame that would be! (sorry just being sarcastic) :devil:
    Seriously tho iv'e downgraded with no probs and iv'e spent more time on the psp than ever. if newer games such as gta force an upgrade i'll just use wab changer. The only thig re v2.0 i miss is the wallpaper, but i guess i'll live
  9. BuFF DaDDy
    BuFF DaDDy
    Jun 2, 2005
    3,297
    +146
    Theres a man with some sense!
  10. ddavewoods
    ddavewoods
    Jul 24, 2005
    561
    +39
    Successfully downfraded from 2.0 to 1.5 today, it was easy, and trouble free, and its just as easy to re install 2.0 so I would recommend the downgrade...
  11. bluevortex
    bluevortex
    Feb 6, 2005
    1,927
    +80
    where do you get your games from to play after downgrade from 2.0 to 1.5?
  12. superjim
    superjim
    Buy them as usual of course
  13. Simebaby
    Simebaby
    Sep 17, 2004
    793
    +22
    WAB Changer won't work with GTA - it has to be running the actual 2.0 firmware.
  14. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,393
    +850
    GTA uses the video codec in the v2.0 firmware to play its videos, so unless someone re-encodes all the gta videos, I doubt we'll be able to play it on v1.5.
  15. ddavewoods
    ddavewoods
    Jul 24, 2005
    561
    +39
    it only takes 5 mins to upgrade / downgrade the firmware, so no problem if you want to have a spell on GTA just upgrade to 2.0 again
  16. pspzones
    pspzones
