down loading files from remote central?
Discussion in 'Home Cinema Control & Remote Controls' started by grahamricho, Feb 13, 2002.
  1. grahamricho
    grahamricho
    Oct 29, 2001
    781
    York
    +20
    just got my pronto,downloaded pronto edit.how do you after downloading files from remote central,open them into pronto edit.my icons are not the same yellow icon as it says they should be.when you click on them it says NOT VALID PRONTO CONFIGUATION.any help???????
  2. Couch Potato
    Couch Potato
    Graham,
    I'm not 100% on this but I think there's a difference betwee the way the ccf's are saved for Pronto v Marantz, there's more info over at http://www.remotecentral.com any problems you're probably better off posting there.
    Steve
  3. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    The files on Remote Central are in the zip format so you'll have to extract the files using Winzip (or any other program that supports zip files).
    Both the Marantz and the Pronto use the same ccf files so that can't be the problem.
  4. Couch Potato
    Couch Potato
    Alan,
    I've had a few problems loading up newer "Marantz" ccf's so it's not only down to extracting the file, although that would help ;)
    Steve
  5. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    are you sure that the file you are trying to load is the right size? If the CCF is for a 2mb remote and your trying to loadit into a 1mb remote i would imagine that you are going to have some problems - when you download ccf's from remotecentral they do say "optimised for Xmb"
    Hope that helps
    Gary
  6. jay
    jay
    Hi I have a maranze rc 5000i which i droped and the screen is cracked.I am hopeing to buy a philips Pronto will i be able to load my confi onto the pronto.
    Jay
