Double sided DVDs
Discussion in 'Movie Forum' started by john59, Mar 5, 2005.
  1. john59
    john59
    Aug 27, 2004
    397
    Wigan
    +20
    Not sure if this is the right place to ask this but here goes.
    Double sided DVDs, are there any draw backs with these disks? I was going to order the film Color purple from play and they only have the double sided version in stock @9.99 but never having owned a double sided DVD I am a bit wary about buying.
    Regards:smashin: .
    John
  2. nwgarratt
    nwgarratt
    May 5, 2002
    27,189
    +3,038
    They just require the disc to be turned over at the appropriate time.
    I would be a bit more careful when handling them though, as there is data on both sides.
    I have quite a few double sided discs and never had a problem.
  3. Erling
    Erling
    Dec 4, 2002
    81
    Denmark
    They don't all necessarily have to be turned over. I have a couple where there are a widescreen/16:9 version of the movie on one side, and a 4:3/pan & scan version on the other. Also have a concert DVD with The Corrs, where you get a PCM soundtrack on one side and a DD 5:1 on the other, so you may not have to leave the couch mid-movie, despite it being two-sided... ;)
    Cheers,
    Erling
  4. CrazyHorse
    CrazyHorse
    Apr 17, 2003
    4,147
    +306
    DON'T order that 2 sided version of Color Purple!
    It's the old flipper disc that has been around for ages with a poor transfer and no real extras, plus it's 2 quid more than the newer S.E.!
    Order the S.E. even though it shows as 'out of stock' - better transfer & value for money, plus the film on one side of the disc. Play are usually pretty quick at getting things back in stock anyway and it's worth waiting a little bit for the far superior version of the DVD.
  5. john59
    john59
    Aug 27, 2004
    397
    Wigan
    +20
    I ordered it last night but will cancel it today and order the SE version, Thanks for the tips guys.
    Regards
    John
