double hinges...
HouseTonyStark
so, in my (mostly) rebuilt lounge i have a pair of doors which open into the dining room, which is fine a lot of the time, but I'm sitting here thinking to myself:
What if i made them double hinged? i have to take the doors down to strip and redo them/the frame etc. it cant be that expensive?
has anyone done this/ got any thoughts they might share with me on whether this is a good/bad idea?
Rorifett
If you're going to all that effort go the whole way -
images
Tempest
I need to see drawings as I've no idea what he's on about. Double Hinged!
Tempest
So he's in his lounge, considering the benefits of "going both ways" ?
Well, I suppose being open to both avenues, gives you more options as you move forward.
DIYlady
One downside is that you'd have to remove the door stop from the frame and possibly reduce the size of the doors to enable them to swing both ways. This would mean that even when the doors were closed you'd have quite a gap around them
You also might find that the doors have to be propped open if you need them to stay open
Tempest
My Engineering mind thinks that looks over complicated :)
Why not scrap that complicated double hinge, and then (this has to come in a pack) have a little plate with a hole in it that you fit to the floor (under the end of the door which has to pivot) and another to the ceiling.
Then on the top and bottom of the door, you drill and fit 2 more plates with sprung metal pins, 1/2" dia perhaps.
Then all done, drop the pin on the bottom of the door into the hole in the ground and spring back, to fit, and release the top pin to spring up into the ceiling hole.
Think of this, exactly like how a normal watch strap attaches to the body of a watch, but on it's side.
when finished, nothing to see, no hinges to paint, or not, and door will swing totally free.
Hey the door could theoretically do a 360 degree spin then. :)
IronGiant
It would probably sag unless there was a wheel at the bottom of the door to support the weight of the door :D
Tempest
Sonic67
A downside I can see is that at present you know which way the door opens and closes. So on approach you may be a little wary of someone on the other side opening the door in your face. Now it could be in either direction.
IronGiant
Why is it a problem, "some of the time" then? Is it that they protrude into the dining room and don't fold back against the wall?
Pictures may help :)
HouseTonyStark
for one thing, light switches on both sides, for another, there would be occasions where the outward swing of the door requires more space than i maybe have at the time
IronGiant
Ah OK, thanks. If they hinged into the living room only, would they still be a nuisance?
nvingo
The two-way hinges won't fit straight onto a (brick-width) door frame, you'd need a door-thickness strip on the face of the door frame to mount the hinges to.
The floor/ceiling pin idea is good (but more complicated than it needed to be in @Tempest's description - fit the pins into the holes first then attach the doors) but have the disadvantage that they won't open beyond 90º each way like hinged doors do.
Without the shuts, there might not be a good seal, but with modern whole-house heating that oughtn't be an issue.
Open the doorway out to four door-widths and suspend the doors on tracks. Cover the extra width with plasterboard each side and make good. Fit a pneumatic piston* at the top which separates the doors whenever the PIRs you fit in each room detects an approaching body and closes them after a short delay. Sorted.
*another method would be to have a constant supply of air to the piston, which exhausts via a rubber tube run across the floor each side of the doorway. When the tube is trodden on, the air no longer escapes and the piston is pressurised.
HouseTonyStark
Im struggling to see why?
Tempest
I'm just REALLY annoyed, 30, 40? years on we still have the same old crappy door on hinges.
What happened to the Star Trek type doors I was sure was going to be in all homes by now?
Why don't they make hollow wall sections as standard by now that all doors can slide into?
Isn't rocket science....
Latest News
What's new on Sky and NOW UK for February 2022
  • By Andy Bassett
  • Published
Piega launches Ace Wireless speakers
  • By Andy Bassett
  • Published
M&K Sound launches V+ Series subwoofers
  • By Andy Bassett
  • Published
Denon launches DHT-S517 Dolby Atmos soundbar
  • By Andy Bassett
  • Published
Perlisten Audio launches loudspeaker ranges in UK
  • By Andy Bassett
  • Published
