Double Gem to big For new house any smaller options
funkyirishman
Ok had the BK Double Gem in old house and new house room not big enough and to awkward to do wiring via the fireplace.
So looking for a subwoofer that packs a punch but is small in size. Linking it to a Denon AVR-X2500H
No budget as of yet but dont want to blow everything on it. Something decent that I can use until I can find space for the Double Gem
Any suggestions?
Gasp3621
Have you thought placement at rear of room if possible, assuming the wiring would be easier to run there? Remember the driver doesn´t need to point toward listener so you can keep the sub "sideways" if this helps some.
Another option if you can fit the sub at front and you don´t have problem with the power cable connection, but rather with the sub cable. Wireless kit might save you then. Don´t have much knowledge of these, just that they work best close to each other (receiver).
funkyirishman
Would wireless kit work with double gem if so that would be perfect. Would be less than 10 feet apart. I have the woofer in place it's the wiring that's the problem.
If these wireless kits would be perfect
gibbsy
REL subs come with a (somewhat expensive) wireless kit called the Longbow, can be fitted to any sub with the i after the model number.
Gasp3621
Call the dealer tomorrow and have a chat! It should work with the 3meter distance if you keep both devices on sight so they "see" each other.
Bronze458
I would also recommend the monitor audio wireless kit.
I had a similar issue with having to place the sub in the back of the room which made cable management difficult.
The monitor audio kit works great , very happy with it overall in it was cheaper than the comparable offerings from svs etc.
I've noticed no change vs using a regular cable , you just have to let the amp set the distance on autocalibrate. I've had no issues with connection but have heard line of sight between the transmitter and receiver is needed.
funkyirishman
Yes went with the monitor audio wireless kit waiting on delivery
Problem is won't be in direct site of each other so hopefully no problem
Podcast: Marantz SR7015 & NAD T 778 AVR + Mission LX2 MKII Speaker Reviews, AV & Film News and More
