Double DVD cases
midlander
Anybody know where I can buy some double width double DVD cases online? I looking for the sort Criterion use, not the ones that look like a single Amaray with a flap holding the second disc.
Don't mind paying over the odds. Need about 5-10.
Martyn
U
Underscore
Originally posted by Matthew Attoe
Online, try www.svpcommunications.co.uk
Coincidentally, I just received an order from these guys yesterday, including 1, 2, 3 and 4 DVD cases. The 3 and 4 DVD cases do include a flappy bit but the 2 DVD case has a DVD mount on each side of the case, which release nicely when pressed (unlike but Blues Brothers/2000 case I have, where you nearly need to fold the DVD in half to get it off the mount. 1, 2 and 3 DVD cases are all standard Amaray size, so will take the standard artwork, while the 4 discer is about 50% thicker.
HTH,
_
midlander
Thanks for the replies but I'm specifically after the sort Criterion use and SVP don't do them. They're wider than normal cases which is important because the artwork won't fit in.
Regards
Martyn
Will K
The type you're after are AlphaPak cases, but I don't know where to get them, sorry.
65-inch LG C1 Review coming soon to AVForums
