Double DIN Fitting
Discussion in 'Video Streaming Boxes & Services' started by DigiDunk, Mar 26, 2006.
  1. DigiDunk
    DigiDunk
    Will a Double DIN Radio CD from Mk5 Golf fit electrically/mechanically into a 2004 Polo which can take the double stacked Radio Casette / DVD player.
  2. Ayub
    Ayub
    Oct 15, 2003
    6,647
    Bradford
    +612
    Yes, i dont see why not. You have to create inputs/output cables but it should fit. I suggest before you undergo such task to see CLEARANCE behind the dash and if the "plastic trim" is going to fit ( i dont think it will).
