"dot crawl" on xbox.
Discussion in 'Xbox Forums' started by TheGuyWhoWonThe, Feb 13, 2003.
  1. TheGuyWhoWonThe
    TheGuyWhoWonThe
    This is really starting to annoy me now.On my xbox games,especially halo theres like moving pixels on the edge of objects.It doesn't happen on anything else dvd player etc.I'm using the official microsoft av cable.I hope this makes sense.any ideas?
  2. Robson
    Robson
    Is the DVD player connected to the same scart socket as the XBOX, or are they connected to 2 different sockets on the TV.
    Perhaps you only have 1 RGB enabled scart socket?
  3. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Yep, the only way to eliminate dot crawl is through your RBG scart. If you're inputting a composite signal you'll still get dot crawl.
    I connect my x-box through a Joytech advanced cable using s-video and use my RGB scart for my dvd. The dot crawl is still present but is less objectionable than on bog-standard composite.
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,053
    +1,130
    My RGB is clean as a whistle: are you sure its not just aliasing?
  5. JUS
    JUS
    Jan 21, 2003
    3,168
    Plute
    +214
    What are you displaying it on ?
    I noticed some very slight movement Halo on the edge of the gun you holding. I only noticed it when viewing on a 7.5ft screen. I had played through the whole game on my 28" tv and not noticed it. I looked on my 28" tv after seeing it on the 7ft screen and saw it..but I had to look hard for it.
    Jus.
  6. AndyZetec
    AndyZetec
    Feb 16, 2003
    17
    Belfast
    If the cable you are using is the one which you got with the xbox, it is only a composite cable, and not capable of carrying RGB, you will need to get a RGB cable like the Microsoft Advanced scart, or a 3rd party product.
    Cheers,
    Andy
