Doom 3 and Farcry
Discussion in 'PC Gaming & Rigs' started by sjp1966, Aug 26, 2004.
  1. sjp1966
    sjp1966
    Oct 29, 2003
    544
    Kent
    +10
    Is anyone able to run Doom 3 and or Farcry with maximum graphic's and antialiasing etc without any problems.
    if so, what are the specs of the machine your running it on.
    I am thinking of upgrading my machine and i want to know what to upgrade to.
  2. Squiffy
    Squiffy
    May 23, 2002
    11,656
    Ashford, Kent
    +5,010
    I can run both games at 1600 x 1200, highest quality settings and maxed AA / FSAA, and all on a P4 3.0 and 9800 Pro.
    It makes for a very pretty slide show! :D
    No machine available can run Doom3 properly with max settings as it requires a 512MB graphics card.
  3. sjp1966
    sjp1966
    Oct 29, 2003
    544
    Kent
    +10
    is it a slide show or does it run smootly :rolleyes:
  4. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,424
    2
    In a secret location with Jennifer Lawrence
    +9,122
    I have a P4 3g with 1gig ram and Far Cry runs perfectly on high setting at 1280 res.
    No noticeable slowdown.
    Greg
  5. headfullofcrisp
    headfullofcrisp
    Apr 15, 2004
    1,028
    Ingleby Barwick
    +25
    I have a xp2800 with 1gig of memory and a 128mb 9800 pro and far cry runs perfectly on high setting @1280x1024, but doom3 i have to tone the res down to 1024x768 on high setting or else it occasionally starts to stutter.
    cheers headfull
  6. Ethics Gradient
    Ethics Gradient
    Jul 29, 2003
    3,680
    aka Billy Science - Suni ojna Tas
    +430
    I've not tried running at ultra settings yet - just High @ 1600x1200 - but it plays very smoothly - will give it ago on ultra this evening.
    I'm using a x800xt equiv ( x800pro modded to xt pe ) - should be even smoother on a 6800ultra.
    ...... and thats on a 2500+ barton unclocked as my vapochill cooler is out of action till i get a new psu.
  7. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    X800 pro isnt anywhere near as good as the XT. Not because of the clock but because it only has half (8 instead if 16) pixel pipes.
    Not so for the Nvidia cards (GT vs Ultra) I clocked my GT to Ultra speeds so it is exactly the same, spec wise.
  8. Ethics Gradient
    Ethics Gradient
    Jul 29, 2003
    3,680
    +430
    Incorrect - the pro comes as standard with 12 pipelines not 8
    If you noticed I said my card was 'modded' to be a x800xtPE - that does not mean I just upped the clock rate - its a full mod.
    16 pipelines - xtPE bios and clock speeds for cpu and ram
    And I think you'll find x800 pro vivo's are virtually identical to the xt pe's - they just have the extra pipelines soft mod disabled ........... why do you think I bought one.
