Dony
Finished Pics in Post 29
Ok....so the slowest lounge build in the history of AVForums has moved on very slightly, and I hope to have it completed in the next few months.
First job was to remove the radiator from the tv wall and relocate to the other side of the room.
I'm now making a checklist/timeline of what all needs to be done from now to completion. Any help or tips from those who have done this before will be very much appreciated. If you see any obvious flaws in my plans don't be afraid to speak up
The wall is concrete block.
Next job I need to do is get an electrician in to install 4 double sockets at the bottom of the main wall (where the radiator came off). I'm hoping he can run some sort of extension from the sockets on the left of the picture. I'm also hoping that I'll be able to turn off all the equipment from the existing socket position, rather than having to do the old "reach around"
Next up will be a wall bracket for a Pio 5090. I don't need it to be cantilever, or even able tilt, so will probably go for a flat bracket. The tv will be mounted at eye level when seated.
Speaker cable is next on the "to buy" list. I had thought about channelling the concrete floor to the back of the room for the rear speakers, but hope that I can get away with cutting a piece out of the underlay for the wooden floor that's going down. I was able to do this with Van Damme blue cable for my office. I could be convinced to channel it if preferred by those more experienced than me.
Wife wants me to buy the unit that will house the equipment at the beginning of the project, as the width of it will be crucial to the width of the floating wall. I'm thinking of 2 of THESE
Sky HD will also need to be fed into the room at this stage. I already have it in the room on the other side of the wall, but will have to run the cable around the side of the house and in beside the existing plug socket.
Only then will I be able to start getting the framework on the wall.
This room has never been completed since we built our house, so it needs totally decorated with a wood burning fire and wooden floor going in. At this stage I haven't put much thought into colour schemes etc.
So, please feel free to chip in with any handy tips, or if you were doing it again anything you'd do differently.
Cheers all.
Cheers all.
