dont worry bout the sub
Discussion in 'Home Cinema Buying & Building' started by oracleband, Feb 14, 2005.
  1. oracleband
    oracleband
    Because the frequencies coming from your sub are so large(around 60 a second as opposed to as high has you can hear which is about 19000 a second) unless you room is massive it dont matter also bass frequencies dont bounce off anything unlike higher frequencies so it also doesnt matter were you put it, you wont notice if you put it behind you in the left corner or centreas long as you dont cover the port.
    This is also why when a neighbour plays music you hear the bass because all the higher frequencies are bouncing around in their room but bass lower bass doesnt bounce it penetrates like a nuclear explosion stopping at nothing.
    So if the neighbour is noisy tell em to turn the bass down, it shouldnt make much difference to them but it may stop you from attempted homocide
  2. theo cupier
    theo cupier
    Sep 18, 2004
    1,649
    63
    Amersham, Bucks
    +113
    oracleband, two points:
    1. Not sure what homocide is, but don't tell Peter Tatchell! :rotfl:
    2. Don't go on to the subwoofer forum of these message boards and tell the guys there that turning their bass down won't make much difference to them :devil:
  3. gpender
    gpender
    Sep 21, 2002
    272
    oracleband what are you going on about? This seems to be a reply to a question that was'nt ask.....yet you've managed to give some bad advice.
    Talk about a little knowledge being dangerous :rolleyes:
  4. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    What are you goin on about mate :confused: What is this statement all about. Besides the fact that what you have said is almost completely wrong it just seems like your trying to provoke someone into an argument :thumbsdow
  5. Henry
    Henry
    Aug 9, 2000
    2,162
    Hull
    +52
    Bizarre. In one of his other posts, he seems to be offering his services as an audio calibration expert! :eek:
