Looking to mount my 50" plasma (PS50A556 bought in 2008) to chimney wall (external chimney so wall is flat).
A relative has given me their universal mount which they never used. The screws are 100mm long which is the width of the brick.
I don't want to drill through the brick into the chimney cavity as this may let fumes into the living room if we use the gas fire again.
Can I use a smaller length screw around 50mm i.e. half brick width?
or anyone recommend a mount that comes with smaller length screws and is capable of holding up a 50" plasma.
Any suggestions on how best I proceed with this gladly appreciated.
Thx.
Thx.
