Dont know what this connection is
Discussion in 'Cables & Switches' started by watahero, Oct 22, 2005.
  1. watahero
    watahero
    Sep 10, 2005
    4
    This is a connection in the built in sound system of the flat. I cant see to find a connector like it. Can somebody tell me what it is or where I can buy it.
    It has 8 pins in a circular manner.
    thanx for any help
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    8-pin DIN. I can't imagine why they'd preinstall it into a flat though. :confused:
  3. watahero
    watahero
    Sep 10, 2005
    4
    8 pin din has this diagram but my connector dose not have the central pin the number 8. is it not standard?
  4. Bolf
    Bolf
    Jul 22, 2005
    408
    The Deepings
    +34
  5. rhino2k
    rhino2k
    Oct 20, 2005
    6,128
    +1,322
    looks more like a shuttle type connection to me, so you can connect say a cd seperate of the same make to it, and use the same remote ect.
    of course that may not be the case at all, it just looks a bit like that to me :)
    posting unit info will help, or look up the model number on google and you will no doubt find a diagram/manual that will tell you :smashin:
  6. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    Blimey I haven't seen one of them for well over 30 years as my old Rogers amplifiers used those DIN connectors.
  7. watahero
    watahero
    Sep 10, 2005
    4
    thanx for all the info. been searching on the net for an adapter that turns this into normal stereo plugs or anything else normal home applinaces use, but couldn't find anything. am I subossed to make the cableing myself?
  8. Peridot
    Peridot
    Aug 24, 2004
    2,995
    Newport, South Wales
    +293
    It's a long time since I've used DIN connectors, but I have a faint recollection that the 7 pin socket is compatible with the most common 5-pin plug used in audio applications. So provided you don't need whatever pin 6 does, you may be able to get some pre-assembled leads.
    Maplin certainly sold 5-pin DIN to phono leads in the past - not sure whether thsy still do.
  9. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    I don't know where you are but after searching everywhere for what I wanted
    (CVBS din Plug all wired ready to plug in)
    and given up,
    I was wondering down Walthamstow Market on my way to the pound shop and on one of the electrical stalls was an old faded dusty packet with a CVBS din!!!!!! with all the converters you could possible want and phono being one of them!!!!
    Never would have guessed to look a market stool for something so out of date.
  10. watahero
    watahero
    Sep 10, 2005
    4
  11. Peridot
    Peridot
    Aug 24, 2004
    2,995
    +293
  12. brendank
    brendank
    Dec 13, 2003
    684
    drogheda, co louth,ireland
    +6
    its a din connector used for connecting bang olufsen speakers/equipment
    7 pin connector normally used for auxilliary connection
    looks like you found a beolink convertor or something send bigger picture and i will be better able to judge
    if thats in the wall do a bit more rooting around as there may be other b+o kit
  13. Dave R
    Dave R
    Jul 14, 2000
    57
    Bristol, UK
    I was going to suggest B&O as well. From memory when I was in the trade (almost 20 years ago now!) they were used as the connection between amp and other components, eg; CD player, cassette deck, etc.
    5-pin DIN connections were often used at that time, which was a common ground, plus a left and right signal for both play and record. The sixth and seven pins were used as some type of control connection so that if you pressed play on the CD player it would switch on the amp and select the CD input (etc.)
    It also maintained compatibility with non B&O equipment, ie; you could plug your non B&O deck in to your B&O amp using it's 5-pin DIN plug.
    Possibly (I can't remember now!) they may also have been used for the MCL kit (Master Control Link) which was a system for routing the sound around your house. The system would be in one room, with just a pair of speaker and a I/R receiver in the remote room. Can't think where though, there was a control module which I think had screw terminal connections for the wires running back to the central system, 2-pin DIN plugs to connect to the speakers, and something to plug the I/R receiver in. But I think that was a smaller connector, or maybe that was hard wired as well.
    They sold dedicated wall sockets with 7-pin DIN or 2-pin DIN connectors on that fitted a standard electrical back box. In fact I've probably still got some in the loft!
    Is it a new flat? I know some of the ones in Bristol, and presumably elsewhere as well, have been pre-wired with the neccessary cabling to run MCL (or whatever they call it now) around the flat. Don't know if they still use 7-pin DIN but they might.
    Hope that helps.
  14. brendank
    brendank
    Dec 13, 2003
    684
    +6
    definetely b+o, probably earlier mcl version
    would be a bonus if whole flat is prewired
    mcl has been replaced by masterlink cable but you can combine mcl with masterlink(ml) via a convertor
