Don't do this!
Discussion in 'Home Cinema Control & Remote Controls' started by metal guru, Jan 4, 2007.
  1. metal guru
    metal guru
    Jan 3, 2007
    29
    3
    .....like you need reminding. About a month ago I put some cheap unbranded batteries in dvd remote "just till I get some good ones". Well one has leaked hasn't it and gunged up the battery compartment. Decent dry cell batteries my primary new year resolution!
    metal G
  2. daveaka
    daveaka
    Jun 16, 2006
    1,980
    Willington, County Durham
    +266
    The same thing happened to me with my amp remote, i will only use Duracell or energizer now, hey ho you live and learn...
