Don't do this with the Tosh RP!
Discussion in 'General TV Discussions Forum' started by nathan_silly, May 21, 2003.
  1. nathan_silly
    nathan_silly
    Well I've accidentally pressed "Copy NTSC Wide to Others" not cleaver!
    It copied the convergence settings from NTSC wide to NTSC superlive, subtitle, cinema etc..
    Not too much damage, though. It's basically messed up the grid sizes for all NTSC modes (PAL is untouched)
    It's made each grid suffer from bad geometry- trapezoidal shaped. So I had to straighten these out, and probably need to get acetate sheets with layout of each aspect as they aren't perfect.
    At least it hasn't screwed my set. I'll be more careful next time.
    So just be careful.!:rolleyes:
