Donon SCM51 = M30?
Discussion in 'Home Cinema Speakers' started by pragmatic, Jan 1, 2005.
  1. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
  2. Astaroth
    Astaroth
    Jun 22, 2004
    2,254
    48
    London
    +97
    As far as I am aware they are not the identical speakers - the speakers predate the release of the M30 range by a considerable amount - though they look closer to the M30s they were released not too long after the m70 range if memory is correct.
    It is not surprising that they have a Mission like appearance as they are made by mission and then badged to Denon.
    Back when I was getting my Denon mini system I compared the SCM51s against a pair of M71i speakers and decided the M71i were alot better and so bought missions M74i (decided my room could take a set of floorstanders).
  3. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    If they were out alot earlier, then it's probably the case that mission liked the looks an keep it for its future speakers. Thanks that certainly helps, will probably go for some m30i's instead.
