Dongles
Discussion in 'Desktop & Laptop Computers Forum' started by baldbird, Jul 17, 2003.
  1. baldbird
    baldbird
    Ok, I know that dongles can be used to connect wirelessly, but am i right in thinking there are lots of different dongles for various puropses ..... :confused:
    I may just be a bit dull, but can't really get much info on the net - anyone wanna fill me in ?
  2. nathan_silly
    nathan_silly
    Some dongles are for copy protection, usually bundled with expensive software (CAD etc)
    The software will not work without the dongle. In the dongle there usually is a PCB with a couple of IC's, and when the software starts up, checks for the existance of the dongle; and also the code on the chips. Normally plugged into the serial port.
  3. HMHB
    HMHB
    Nov 11, 2001
    25,605
    Nottinghamshire
    +3,958
    You can buy dongles and program them yourself to do whatever you want. We used to buy them in bulk at work to protect our software.
  4. John_N
    John_N
    ... An example might be that the dongle can generate output values for a given input value, or you could maybe embed a certain vital program function within the dongle. You could also use the dongle to make decisions within the program logic. Basically, it is possible to do it in such a way as to make it very very hard or virtually impossible to take the dongle "out" again by just bypassing a simple"is the dongle connected?" type program branch.
  5. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    ATi's component adaptor is a dongle.
    MuFu.
  6. baldbird
    baldbird
    Thanks for the info so far, but......
    Anyone know's if there's such a thing as a dongle that converts and ide hard drive into a serial ata ????????
    :confused:
  7. John_N
    John_N
    I think a company called 'acard' do hard disk adapters. They certainly make IDE to SCSI adapters (allowing you a cheap SCSI disk from an IDE drive) and I think they do a parallel to serial ATA convertor as well.
    Look at www.acard.com for details
    John
  8. baldbird
    baldbird
    cheers John
  9. VintageMark
    VintageMark
    Apr 27, 2001
    160
    16
    Bristol
