Domino45 : stereo speakers as center ?
Discussion in 'Projectors, Screens & Video Processors' started by Trab, Feb 18, 2005.
  1. Trab
    Trab
    can you easyly switch the internal stereo spaekers of the Domino45 into one center speaker wihch is driven by an external amplifier with pre-outs ?
    if it can, would anyone recommend such an installation ? the specifications are not identical : 2x20W or 2x40W ?
    the fact that we won't install a center speaker is four aesthetical reasons !
    thx
    Bart.
  2. AD Roser
    AD Roser
    Aug 23, 2002
    280
    East Sussex
    +17
    Bart,
    There will always be issues with Timbre matching when you use different speakers - it will be especially noticable with pans from left-cntr-right.
    The option of using the internal speakers is really down to convenience. One would assume that if your speakers were of a high calibre you would not use the internal spekers of the Domino45 however if your system is based on one of the many "Home Cinema Packages in a box" then you may want to consider using the Internal speakers. The bottom line is try it and see.
    Regards
    Alan Roser
    SIM2 UK Ltd
