Domino20 quick advice needed
Discussion in 'Projectors, Screens & Video Processors' started by gandley, Nov 9, 2003.
  1. gandley
    gandley
    Aug 31, 2003
    5,049
    Paradise Lost
    +269
    I have found a domino20 at quite a good price but have been informed it has one lazy mirror. it has a high bias so will fire ok on bright scenes but on darker it flickesr gray.
    but the guy said it will be unoticable becuase it is below centre which generally dosent get lit up.
    im not a DLP pro so if any one can tell me if this sounds right or if im best staying clear i would be grateful
    but it is £500 pound cheaper.
  2. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,752
    Outpost 31
    +205
    Believe me, you will wish you had spent the £500 extra once you spot where the problem is and then can't help but notice it every time you watch a movie with a night/dark scene!
    Your eyes tend to concentrate on the center of the screen - below center could mean one inch below or 2 feet below! If the mirror is at the very bottom of the screen I'd possibly take the chance but only after I had seen it in action. If its anywhere near the center of the screen, forget it.
    It might not bother you today, it will a week/month/years time.
    Paul
  3. gandley
    gandley
    Aug 31, 2003
    5,049
    Paradise Lost
    +269
    PaulB.
    thanks for input.
    Ill chat further with the company to ascertain exactly the proplem in more detail.
    But as a guide i appreciate your input. Nice one
  4. Kramer
    Kramer
    Can/will have an effect (detrimental) on the resale value should you wish to upgrade down the line.
    :smoke:
