Domino picture settings
Discussion in 'Projectors, Screens & Video Processors' started by Nuno Santos, Apr 1, 2005.
  1. Nuno Santos
    Nuno Santos
    Jul 25, 2000
    148
    Portugal
    +3
    Does anyone know what the "Filter" setting does exactly? It seems to affect the sharpness of the image (as mentioned on on the manual), but I can't quite figure if I'm doing more harm than good. How are your settings?
    Does the Overscan setting affects the deinterlacing and/or scaling performance of the projector or are non related?
    NS
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Sharpness and Filter settings both have an effect on picture sharpness. As far as I know the Sharpness setting works within the analogue circuitry whereas the Filter setting is in the digital cicuitry within the projector.
    The factory defaults are 4 and 4 which is too high.
    A good test pattern to check these settings is tha Avia Widescreen Enhanced Resolution Pattern where you will see a lot of white edge enhancement that will diminish if you back off both settings by a couple of points.
    Remember, if the sharpness settings are too high you will be addding information (edge enhancement) that was not present in the original material.
    The Overscan adjustment should have no effect on deinterlacing or scaling performance.
    Jeff :rtfm:
  3. Nuno Santos
    Nuno Santos
    Jul 25, 2000
    148
    Portugal
    +3
    Thank you Jeff, for your help.
    I did some testing with DVE's sharpness pattern and concluded that the Sharpness control had a worse effect on the picture's edge enhancement than the filter control. I ended up with 2 on Sharpness and 4 on Filter.
    NS
