Domino 30h
Discussion in 'Projectors, Screens & Video Processors' started by dion, Jan 4, 2005.
  1. dion
    dion
    I have a DOMINO 30H which is installed on a sim2 ceiling mount. The projector seems far noiser than the 1 we demoed. Does anyone have any suggestions?
  2. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,105
    Portsmouth / Middle East
    +77
    Yes you can return it if it was purchased within 28 days or try leaving it switch off permanently.
    CH
  3. AD Roser
    AD Roser
    Aug 23, 2002
    280
    East Sussex
    +17
    Dion,
    The bracket may induce a little more noise than if the unit was desktop mounted. There are small tolerences in the fans or colour wheel that can cause a slight difference in accoustic noise.
    Sometimes the ambient noise within the location where you had the demonstration could be higher than in your home - Air conditioning for example.
    Useful comments from cool-hand serve no purpose, but if you are concerned then have a chat with your dealer for advice.
    Regards
    Alan Roser
    SIM2 UK Ltd
  4. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,105
    +77
    How do useful comments serve no purpose!?!? :clown:
    Easy Tiger....!!
    CH
  5. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,105
    +77
    Hi Dion
    only kidding.... seriously though, Sim2 pj's are to die for and if the Dom30 was a little better value (pound for pound IMHO) I would, and alsmost did go for it.
    Im sure SimUK are, as all pj makers... working on a way to quiten the thing down. If they did I don't think many people would have much choice but to buy it everytime!
    CH
